Browse Forums Windows & Doors 1 Jan 12, 2013 11:02 am If you have windows that are ~30cm high and range from 1.2 to 2.1m in length, at around the 1.4m from the floor to the sil (or maybe higher), what is the best option for how they should open? I want them to open for ventilation/cross draft purposes and they will be double-glazed units. Awning? Casement? Can they be casement style with the hinge at the top so they open like awnings but can go all the way to horizontal so the whole area is open for airflow? In the case of a high (above head height) mounted window, what is easiest to operate? Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Openable wide but small height windows. 2Jan 18, 2013 10:37 am Hi dragonchild, For those windows you could go with awning or tilt in windows with restrictors. For the above head height mounted windows you could get a motorized remote opening (with a switch). I reckon the best thing you could do to find out would be to send the measurements to window companies that do double glazed windows and get a couple quotes with what they recommend for your needs. Might give you a clearer idea of what is possible. Cheers, Zilla Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25168 Like pulse said, you can fit drawers however because of the placement of the sink there isn't much depth so you would have to have cut outs for the waste pipes. It all… 2 1317 |
