Browse Forums Windows & Doors 1 Dec 04, 2012 11:16 am Hi, Just wondering if anybody could give me some rough costs on pivot entrance doors vs double entrance doors. We are in the process of getting plans drawn up and we cant decide on which door to get. If there is a cost difference I'm sure that will make up our minds Thanks Re: Pivot door vs double door entrance cost 2Dec 04, 2012 11:26 am I cant help with the cost issue, however if you're building a house with a modern look, i think (imho) that a nice big pivot door looks amazing especially if you have high ceiling and can raise the height of the door.. If you're building a house with a traditional look then double doors would be better with that look... imo. Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: Pivot door vs double door entrance cost 3Dec 04, 2012 12:28 pm depends on the builder...double doors should be cheaper than a 1200mm wide door. the 1200mm door can be put on hinges instead of a pivot which would greatly reduce the cost. the price varies by thousands between builders though... Re: Pivot door vs double door entrance cost 4Dec 04, 2012 3:37 pm Cost for pivot doors varies between 4 & 6 thousand, depending on what door, height etc. Then you have to include whatever the builders margin on top. Most margins are around 20 percent, so would cost yourself as a client anywhere from $4800 to $7000. You can put a 1200km wide door on hinges for a bit cheaper, these can range anywhere from $2500 to $4500. Again, depends on the door, height etc. Double standard entry doors will be your cheapest option, will only be a couple hundred if that to upgrade from a single door. 2 Pivot door vs double door entrance cost 5Dec 04, 2012 7:10 pm I've put a 2340x1200 door on hinges. You can tell the door is heavy ~ 65kg but the door moves freely. I used 4 heavy duty ball bearing hinges, normal hinges won't stand a chance. I couldn't justify the cost of a pivot system. Re: Pivot door vs double door entrance cost 6Jan 16, 2013 12:47 pm Hi does anyone know the width of entrance needs to be to fit a 1200mm door? Thanks Re: Pivot door vs double door entrance cost 7Jan 16, 2013 2:58 pm I wanted to make a 'sweaping' statement with our home (being built - reckon a Feb move in) and a front door is that statement. Hence I picked: Quote: Provide 2340 x 1020 Pivot Door Infinity INFWS 5VG with clear glass and Pull Handle 9248PH750 Horizon in Lieu of 2040mm high Hinged door - Madison PMAD I4G with clear glass. Unquote. Cost all up including the mortise lock thingy: $4200 From all accounts, as yet we haven't seen our home (we're in WA, house being built in VIC) is that it looks fantastic. That's from family and friends. So, my thoughts are go with the pivot door, where size does count. Re: Pivot door vs double door entrance cost 8Jan 16, 2013 6:48 pm bkm2009 Cost for pivot doors varies between 4 & 6 thousand, depending on what door, height etc. Then you have to include whatever the builders margin on top. Most margins are around 20 percent, so would cost yourself as a client anywhere from $4800 to $7000. You can put a 1200km wide door on hinges for a bit cheaper, these can range anywhere from $2500 to $4500. Again, depends on the door, height etc. Double standard entry doors will be your cheapest option, will only be a couple hundred if that to upgrade from a single door. 2 Hi bkm2009 Gee don't no where your building we had our builder in Sydney supply and fit our pivot door Front Door 2340mm H * 1200mm W Corinthian sunburst Grand translucent glass $3,592.00 Door lock and Handle Provide Trilock Omni handle with Rochas lever (8903 ROC BSC) with double cylinder deadbolt to Front Entry door $360.00 all price with builder margin etc Deposit on land 20/03/12 Deposit with Builder 01/07/12 Tender signing 12/10/12 Into Council 20/01/2013 Site work started 30/04/2013 Keys 15/11/2013 What can i do tomorrow better then today Re: Pivot door vs double door entrance cost 9Jan 16, 2013 8:10 pm We upgraded to a 1200 wide door on 4 hinges for $1200. Its a Stain Grade with 4 wide translucent glass panels (hume savoy style from memory) The door it replaced was single standard size with 2 sidelights. Would be a bit more if you only have a single door as standard. If you wan't to be able to fit a screen door at some point, I have been told you can't with a pivot door. We are going to, breaks my heart to cover the door, but it faces west and thats where the breeze comes from so we are, and the extra width will be handy for getting furniture in! Jen Building with HomeGroupWA (started as Scott Park Homes ) - Grand Wisteria Check out my Build Thread!! Time line on P1. Re: Pivot door vs double door entrance cost 10Jan 16, 2013 8:23 pm Thanks for your thoughts. Do you feel your louvre sidelite security mesh is safe? I was thinking no window at all so no one can see if I'm near the front door, shadows… 2 697 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18203 |
