Browse Forums Windows & Doors Re: rotted window frames, wooden 2Oct 14, 2012 4:30 pm leisadent Hi, what type of tradie do I get to replace broken windows AND rotted parts of the wooden frames - builder, glazier, or both? For replacement, go to to a local window company, they may do it, or they should know someone who will. If you replace with timber windows, no problem, if you use aluminium, then use either EcoClassic or A&L, as you need a window that slips into the same hole that the timber window leaves. For repairs to the frame, you need a carpenter, for glass you need a glazier. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7633 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9100 |
