Browse Forums Windows & Doors 1 Sep 22, 2012 1:12 pm Hi all, How much gap should be between the bottom of the doors & the frame? Our front doors have a very wide gap & the laundry door has the same. Enough so that when quite windy & raining the rain gets under the laundry door & comes inside You can even put your fingers through. SS said that the doors will have weather thingys on them,but to me you would poss be able to see them if you bent just alittle & had a squiz. cheers kat Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Gap between bottom of door & frame?? 2Sep 22, 2012 8:26 pm kerry-ann Hi all, How much gap should be between the bottom of the doors & the frame? Our front doors have a very wide gap & the laundry door has the same. Enough so that when quite windy & raining the rain gets under the laundry door & comes inside You can even put your fingers through. SS said that the doors will have weather thingys on them,but to me you would poss be able to see them if you bent just alittle & had a squiz. cheers kat Sounds like your weather thingies are missing... Tell your ss... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Gap between bottom of door & frame?? 3Sep 22, 2012 10:25 pm Yep thats right Ed,no weather thingy! What i am trying to work out is there a measurement that is standard/normal re the height of the bottom of the door to the bottom of the frame.Just like what they leave for carpet or tiling. Due to the big gap under the doors i am concerned that you will see the back of the weather strip when the doors are closed. Wouldn't the gap normally be just off flush?? Front doors, http://i639.photobucket.com/albums/uu120/kerry-ann_03/P1090057_zps6be9cd13.jpg Laundry, http://i639.photobucket.com/albums/uu120/kerry-ann_03/P1090357_zps1e7d6ef0.jpg Thanks Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Gap between bottom of door & frame?? 4Sep 22, 2012 11:12 pm My front door gap is about 1 or 2 mm. Very nice. It's so low that if there i anything larger than a grain sand it scrapes, which is not a problem since I have tiled floors. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Gap between bottom of door & frame?? 6Sep 23, 2012 12:27 am i had similar gap before the weather strip went in. now weather strip is in, i can not see any gap and i don't notice weather strip as well. I was also concerned / worried first like you. So don't worry, it will be ok once weather strip goes in. Re: Gap between bottom of door & frame?? 7Sep 24, 2012 11:51 am Ok thanks guys,i will wait & see how it finishes,cheers! Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 2 7482 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5346 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3545 |
