Browse Forums Windows & Doors Re: Where to find plain flush finish entrance door? 2Aug 24, 2012 12:57 am Corinthian and Hume both make the door you are after. Any door specialist will order one in for you. You can even go to bunnings and order one if necessary. They will probably have 920mm doors in stock. Any bigger and you will need to order it in. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18203 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15796 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3269 |
