Browse Forums Windows & Doors 1 Aug 17, 2012 11:03 am We are planning to soon replace the glass on our current window panes (around 10 very large windows) to double glazed. At the moment one of the windows (with lovely views) has a fixed centre pane and a sash on either side. I'd like to replace it with just one fixed glass pane (low u and double glazed). Size is around 2600x1340. Is it possible to fit the glass pane on the existing window frame? Can you give me an idea of the cost? Here is a picture to give you an idea: http://i1155.photobucket.com/albums/p549/VintageOak/window.jpg close up: http://i1155.photobucket.com/albums/p549/VintageOak/1.jpg Thanks Re: Double Glazing and picture windows - possible? 2Aug 17, 2012 3:44 pm Camber We are planning to soon replace the glass on our current window panes (around 10 very large windows) to double glazed. At the moment one of the windows (with lovely views) has a fixed centre pane and a sash on either side. I'd like to replace it with just one fixed glass pane (low u and double glazed). Size is around 2600x1340. Is it possible to fit the glass pane on the existing window frame? Can you give me an idea of the cost? Here is a picture to give you an idea: http://i1155.photobucket.com/albums/p549/VintageOak/window.jpg close up: http://i1155.photobucket.com/albums/p549/VintageOak/1.jpg Thanks Hi You would need new windows. You also need to maintain ventilation at 5% of floor area in each room or close by. Our price for a 2600 x 1200 open window above a fixed window say 900 wide - all double glazed, fully installed is under $2000. Depending on location and access. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double Glazing and picture windows - possible? 3Aug 17, 2012 6:31 pm Thanks for your response. There are 3 other large windows in the same room, so ample cross ventilation. But wanted this particular one fixed, picture type. Would I have to remove the frame we've just finished painting the room and was hoping to simply have the glass custom made to fit the frame (frame is around 120mm wide). Otherwise, we might have to postpone this project for a very long time! Re: Double Glazing and picture windows - possible? 4Aug 17, 2012 6:57 pm Camber Thanks for your response. There are 3 other large windows in the same room, so ample cross ventilation. But wanted this particular one fixed, picture type. Would I have to remove the frame we've just finished painting the room and was hoping to simply have the glass custom made to fit the frame (frame is around 120mm wide). Otherwise, we might have to postpone this project for a very long time! You need to consult a carpenter... I think it maybe possible for a fixed window. But cost may be higher. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19076 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7673 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16189 |
