Browse Forums Windows & Doors 1 Aug 14, 2012 6:18 pm Hi guys, our internal garage door ie the door from the garage leading into our house, has a gap of 25mm between it and the floor. The raven seals or similar at bunnings don't cover that size gap Is there anything else out there that would fit ? BTW, we don't want to add a piece of timber to the bottom of the door to reduce that gap , or atleast DH doesn't This is not our door, nor is it an internal door, but this'll give you an idea of what I mean : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ TIA Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Gap at bottom of door 3Aug 14, 2012 7:05 pm hey there Lex the door was installed after the tiling. The guy who came around to fix the defects offered to replace the original (hollow) door with a SOLID door. We thought it would be a great idea for the added security between the garage and the house! Plus it was a freebie . We didn't think that the gap would be a problem until the cockies started to visit Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Gap at bottom of door 4Aug 14, 2012 9:14 pm Southies The raven seals or similar at bunnings don't cover that size gap The Raven RP4 - Storm Proof Seal and RP54 - Daniels Rain Stop Seal can seal a 25mm gap. Bunnings should stock these or can supply them as a special order. Both of these have two parts, an aluminium strip that is fastened to the floor and a seal that is attached to the bottom of door. I left a 30mm gap under our doors when I installed them but this was reduced to ~15mm after the flooring was installed. Re: Gap at bottom of door 5Aug 16, 2012 11:57 am Thanks theyetti - didn't think of checking out Raven's website Just assumed that Bunnings would stock all their models. Will get DH to put in an order for the RP54 Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4881 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19264 2 7546 |
