Browse Forums Windows & Doors Questions about different glass type 21Oct 23, 2012 10:23 pm My Knock down and Rebuild thread viewtopic.php?f=31&t=54685 Our Building Blog http://ourknockdownrebuild.blogspot.com.au/ Re: Questions about different glass type 23Oct 24, 2012 1:14 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Questions about different glass type 25Oct 24, 2012 9:08 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Questions about different glass type 26Oct 25, 2012 4:23 pm My Knock down and Rebuild thread viewtopic.php?f=31&t=54685 Our Building Blog http://ourknockdownrebuild.blogspot.com.au/ Re: Questions about different glass type 33Feb 05, 2013 6:55 am leighton I have always believed double glazing is effective at least in part because it has an air gap. These guys think so too. "The formula for reducing noise is to create a large airspace between the 2 windows, using 6.38mm laminated glass and acoustic seals." source:http://www.stopnoise.com.au/about-secondary-glazing.php?Sound-Reduction-4. Also, we use a lot of low e glass on reccommendation and I have certainly found it very effective on hot days. The energy efficiency assessors like it for other reasons. Time to do more homework. I will investigate further. cheers to all The best acoustic glazing involves very thick glass, and air gap only helps if it is over 100mm, but it is the glass that makes the difference. The larger the air gap the lower the heat insulation... 12mm is perfect. Low-E has it's problems, but the one benefit is reducing solar heat gain. Nowhere else in the world is it sold in single glazing, only Australia, for the reasons explained elsewhere. We supply it in double glazing, where it shields 80% of the incoming solar heat gain. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6357 Hi All, This is our second home build and first time with a custom builder. They are small builder and have built some houses with good quality. They tender and color… 0 608 |
