An electric Roller Shutter blows a fuse everytime it reaches the Down limit switch.
If I stop the Down before it reaches the limit swich it works perfect.
What's the most likely cause.
Thanks
Browse Forums Windows & Doors Re: Roller Shutter blows fuse 3Aug 03, 2012 4:36 pm The shutters have been working fine for 12-14years. I found the cause. I removed the cover and found one of the slats had worked to one side and must have occasionally touched a live wire on the limit switch. To fix it I re-aligned all the slats to the centre position by using a screwdriver to move them. I have motorised roller blinds in my house. I motorised all the blinds I use a lot and the ones that don’t get used too often I didn’t. I went through Motorise My… 2 5770 |
