Browse Forums Windows & Doors Re: Window/metal frame making noise 5May 04, 2012 11:33 am dynacker We tried silicone spray last night with no luck. I ended up putting a beach umbrella in front of the window and it stopped the noise for about an hour. I'm starting to think it's the frame making the noise.. Weird... did you spay the glass both sides where it joins the aluminium? If it is expansion, it is the friction making the noise... spray the joins wherever you can see them, both sides. If that doesn't work, I am out of ideas, as I have never heard this before. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8002 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11759 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11655 |
