Browse Forums Windows & Doors 1 Apr 21, 2012 8:53 am I have 4 larger windows and a sliding door installed in my family room. These windows are down to the floor. All of the windows and door (bar one that faces the covered alfresco) has water damage to the timber flooring in the reveal. There is no eave outside and these are subject to the weather. We are trying to find out what may be causing this and think it may be the windows leaking. Going back through photos it seems the flashing that was supplied on the base of the window and doors upon delivery was removed. (side flashing remained). The windows appear to have been installed directectly of top of the kordon orange termite bariier, which is right ontop of the slab. The timber flooring was then installed onto of this right up to the window frame. Could the lack of the flashing be the cause of the leak? Is this the correct practice or should flashing have remained on the windows? If this is the case, what would need to be done to fix it? Really appreciate any help/advice you could give me. Thanks Re: Windows leaking 4Apr 21, 2012 8:10 pm mydreamhome I would .... If I knew how Try join a free website like photobucket.com for example. Then post the [ img ] tags from there into here Re: Windows leaking 5Apr 22, 2012 7:36 am mydreamhome I have 4 larger windows and a sliding door installed in my family room. These windows are down to the floor. All of the windows and door (bar one that faces the covered alfresco) has water damage to the timber flooring in the reveal. There is no eave outside and these are subject to the weather. We are trying to find out what may be causing this and think it may be the windows leaking. Going back through photos it seems the flashing that was supplied on the base of the window and doors upon delivery was removed. (side flashing remained). The windows appear to have been installed directectly of top of the kordon orange termite bariier, which is right ontop of the slab. The timber flooring was then installed onto of this right up to the window frame. Could the lack of the flashing be the cause of the leak? Is this the correct practice or should flashing have remained on the windows? If this is the case, what would need to be done to fix it? Really appreciate any help/advice you could give me. Thanks Yes, that could be the cause especially if the windows and door face a prevailing wind. Here is a link to the industry standard for installation. www.awa.org.au/LiteratureRetrieve.aspx?ID=45900 Make sure it is not condensation running down inside the window. Also check the weep holes under the sills to make sure they are present, and that they are draining. What sort of area are you in terrain wise? Work through the calculator at the bottom of this page... http://shedsonline.com.au/ post the result here. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Windows leaking 6Apr 25, 2012 9:43 pm Hi Ed, thanks for your help - knew I could count on you The windows do face prevailling wind. we have a lake to the back and side of us, and there is no eaves on this section of the house. I attempted to do the calculator as best I could, but was a bit confused on some of the terms, and err'd on the side of a lower rating. these are the results. Region - A Terrain - 3 Sheilding - 3 slope - 1 (was a bit confused. there is no hills, but our block is built up approx 1.5m higher than the lake Location - 3 Estimated Wind rating = N2 Here are some photos (hope they work) This is the windows installed on the kordon orange, with no flashing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ flashing pulled off and laying inside Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ inside view of window Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I do have a few more photos, but hopefully this will give you the general idea. Re: Windows leaking 7Apr 25, 2012 9:46 pm oh, and Ed, I forgot to mention, I am very sure it isnt condensation. The timber floor has absorbed so much moisture that it is rising through the boards in the reveal and causing the coating to bubble, then pop. The flooring is strand woven bamboo. cheers Re: Windows leaking 8Apr 26, 2012 7:12 am From a distance, your windows look to be well flashed - except the head which appears to have no flashing at all. If the windows remained like that after bricking, then that would be a problem - any idea where the water first appears on the inside?. I think your home would be N3, windows should be OK... there will be a sticker somewhere that mentions the N rating or maybe just wind rating and water penetration. G. James windows I think? You could ask them to check them out... a good company. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Windows leaking 9Apr 26, 2012 7:25 am Yes the are gjames! You know your stuff!. So you don't think there is any issue with the black flashing supplied on the bottom of the window being removed and it only sitting on the kordon orange then? Re: Windows leaking 10Apr 26, 2012 11:59 am mydreamhome Yes the are gjames! You know your stuff!. So you don't think there is any issue with the black flashing supplied on the bottom of the window being removed and it only sitting on the kordon orange then? I am guessing they wrapped the orange stuff around the sill, but I don't know... but the head looks like a problem to me... that should have had flashing, maybe the water is getting in at the head - check with the builder, or see if you can see through the gap at the head. Can you see water at the transom (horizontal divider) when it leaks? I can see the weep holes in one window, check they are all there and clear. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24318 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10707 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4665 |
