Browse Forums Windows & Doors 1 Mar 29, 2012 9:11 am I'm trying to work a quote out for blinds off a plan window legend. The owner of the plan more or less pointed to the window width and window height to work off. This I know.....but the sizes are all over the place. The head height on the plan is more to the sizing of normal windows. Which one am I suppose to be working from, window height or head height? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: window head height???? 2Mar 29, 2012 9:56 am Possibly 25c which is about 2,100mm if they have raised the level to 28c it would be 2,400mm. Not sure if that helps. Cheers Mark Re: window head height???? 3Mar 29, 2012 4:48 pm Thanks Mark Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9568 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7754 |
