Browse Forums Windows & Doors 1 Mar 11, 2012 6:45 pm We have just brought a fairly old house that has built in wardrobes in a couple of bedrooms. The built in's are old but sufficient so are low on our "to do" list. The doors of the wardrobes are not mirrored and i was wondering if there either a) some kind of adhesive mirror panel could be applied to one side? b) If there are places where i could purchase replaced doors with mirrors? Thanks Re: replacing built in wardrobe doors 2Mar 12, 2012 9:18 am Maybe i should add, the wardrobe dimensions are H= 248cm W= 78cm And they have two sliding doors that sit on a 7cm wide runner. Ive seen a few mirrored doors in bunnings but the sizes are way off. Thanks again. Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4896 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3071 2 8358 |
