Browse Forums Windows & Doors 1 Feb 19, 2012 7:00 am Hi, I am looking for a supplier for a 2000mm wide single unit cavity slider for an internal wall. Was wondering if anyone was aware of a company which would make one that big? The actual door will be just a solid door which I will paint so doesn't need to be full timber or anything. Height would be 2,400mm. I am in Sydney. Cheers Re: Oversized custom cavity slider 3Feb 19, 2012 12:59 pm wow - that will be one big but beautiful door. I have seen some of those doors in custom homes, particularly between living rooms and foyers. We didn't want to use Corinthian for our front door (as they use merbau timber), so after a lot of research we found a lovely guy at North Coast Doors in Toormina (somewhere on the north coast). We have custom ordered a 1000mm x 2400mm spotted gum front door and it is only costing us $1,500. If you are interested in getting the cavity custom made send me a PM and I give you his details. SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Oversized custom cavity slider 5Feb 19, 2012 3:48 pm thanks all. the purpose of the door is to divide a study/guest bedroom from the second lounge area. the reason for the wide opening is to let in the afternoon winter sun that goes into the study through to the rest of the house, as well as make the study a little more open plan when I am home with the kids but allow my husband to shut them out if he is working from home. we want to make sure the room will still be considered a 4th bedroom should we want to sell in the future so therefore want the door to be solid and not glass. I think I had an initial quote from "Cavity Sliders" but it was more than $3k all up just for the materials (no install) which I thought I could find cheaper. Maybe i'm wrong?? Sunshine T I will pm you. Thanks Re: Oversized custom cavity slider 7Feb 20, 2012 8:49 pm ok thanks PHL. If that's the case we really need to decide how much we really want that door/opening then. cheers. Re: Oversized custom cavity slider 9Feb 22, 2012 8:30 pm Rather than one big slider, can you put two more standard sliders? (That's what we are doing in our entrance foyer). Or a bifold door or something? SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Oversized custom cavity slider 10Feb 22, 2012 8:48 pm On a slightly different note, I have had to try and make a CSD 1800 wide 2040 high work. If you are going to spend a lot of money on a door make sure you have a written gaurantee on how much the door is allowed to bow before they replace it. Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5143 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5638 |
