Browse Forums Windows & Doors 1 Jan 16, 2012 11:04 pm The screen door in the picture has aluminium mesh fitted, instead of having rubber spline going around the door frame, it has plastic trims fitted in the channel to cover the pop rivets that are holding the mesh in place. I have not seen the plastic trim by itself, but I would imagine it has a L-shape cross section, with one side pressed into the channel. Bunnings doesn't have it, anyone seen this selling somewhere? Cheers! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Where can you buy plastic trims like this? 2Jan 16, 2012 11:49 pm Is it rubber or plastic? Also are you in Vic? DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11584 2 10985 |
