Browse Forums Windows & Doors 1 Jul 23, 2011 4:13 pm Hi, Hoping to get some advice on what to do with the French doors I have in the master bedroom opening on to a small balcony. See pic linked below. I would like to have plantation shutters so was thinking of replacing the frosted with thicker clear glass and having the doors open out. This would also mean removing the timber framed screen doors. The room is located at the front of the house on a busy road so security and noise insulation are also factors. Any other ideas? http://gallery.me.com/ny.lon#100042/IMG_0674 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7117 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7147 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 19250 |
