Browse Forums Windows & Doors 1 Jul 15, 2011 3:41 pm Hi, I am trying to replace a flyscreen in my Mum's window, but for the life of me, I can't figure out how to do it. The window appears to have some sort of anti-tamper bar or something like that which seems to lock the flyscreen in there. My Mum bent the original flyscreen to get it out and I made a new one for her, but I just can't work out how to get it in there. Below are a couple of pics showing the flyscreen, the "anti-tamper" bar (feel free to correct me on terminology here), and the window. The second pic shows how little room there is for actually trying to fit this all in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Are you supposed to start with the flyscreen inserted into the recess of the anti tamper bar and then try and wedge it all together, or do you need to remove the entire fixed window and fit it all at once. Any ideas are much appreciated. Thanks, Chris Re: Is there a trick to installing flyscreens in these windo 2Jul 16, 2011 11:35 am I have no idea about anti-tamper bars but most sliding windows require you to remove the sliding pane, then fit the flyscreen from the inside, then replace the pane. That's how ours work anyway, and the design hasn't changed from our old place which was built 25 years ago. Re: Is there a trick to installing flyscreens in these windo 3Jul 16, 2011 11:45 pm Kek is correct. Flyscreens install from the inside on sliding windows like yours. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Is there a trick to installing flyscreens in these windo 4Jul 17, 2011 10:34 pm OK. Thanks for the suggestions. We did try that, but it still looked like it just wasn't going to fit. I'll take another look next time I'm at Mum's and let you know how I got on. Thanks, Chris Re: Is there a trick to installing flyscreens in these windo 5Jul 27, 2011 11:48 pm Installing from the inside, while wedging it in at the top on a 45 degree angle, and then just slotting the bottom part of the screen in worked a treat. Thanks for the suggestions. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 Ask yourself if the insurance company will be aware of the Reno. 4 7369 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8370 |
