Browse Forums Windows & Doors 1 Jul 05, 2011 4:49 pm Hi All The lot we have purchased is subject to an Acoustic Report being prepared. We have had some reccomendations put together, which include about 5 x 6.38mm laminated glass windows and 1 sliding door. Plus 4 x 10.38mm laminated glass windows and a stacker door. The cost the builder has come back with, after reading these recommendations, is over $8000. This seemed really really high to me... Would anyone with a lot more knowlege than me (that's anyone!) happen to be able to tell straight away if that is accurate? I assumed that would be what it might be for double glazing, but I may be completely confused Thank you in advance for any help! Re: Acoustic Report - Window Upgrading Costs... Help? 2Jul 05, 2011 6:49 pm boughtablock Hi All The lot we have purchased is subject to an Acoustic Report being prepared. We have had some reccomendations put together, which include about 5 x 6.38mm laminated glass windows and 1 sliding door. Plus 4 x 10.38mm laminated glass windows and a stacker door. The cost the builder has come back with, after reading these recommendations, is over $8000. This seemed really really high to me... Would anyone with a lot more knowlege than me (that's anyone!) happen to be able to tell straight away if that is accurate? I assumed that would be what it might be for double glazing, but I may be completely confused Thank you in advance for any help! What's the detail of your acoustic report. It will mention Rw or STC value for windows and doors. I think your stacker door is an overkill since it will leak air (and noise) due to the low quality acoustic seals. As an example of performance, our window achieves Rw 34.5 with 8.76 laminate, 9mm air and 4mm clear toughened glass. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Acoustic Report - Window Upgrading Costs... Help? 3Jul 06, 2011 8:30 am Hi Ed, Thanks for your reply The report states that windows > 1.8m2 require min RW35. windows < 1.8m2 require min RW32. entry doors require RW33 So do you mean we should probably get rid of the stacker door if we want to reduce cost? Thanks again! Re: Acoustic Report - Window Upgrading Costs... Help? 4Jul 06, 2011 3:27 pm boughtablock Hi Ed, Thanks for your reply The report states that windows > 1.8m2 require min RW35. windows < 1.8m2 require min RW32. entry doors require RW33 So do you mean we should probably get rid of the stacker door if we want to reduce cost? Thanks again! The specification seems excessive. Air leakage is major cause of noise, stackers have a lot of air leakage. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Acoustic Report - Window Upgrading Costs... Help? 5Jul 15, 2011 12:12 pm $8000 for 5 windows and a door fully installed? Seems quite cheap to me. Re: Acoustic Report - Window Upgrading Costs... Help? 6Jul 15, 2011 2:21 pm Darren Stewart $8000 for 5 windows and a door fully installed? Seems quite cheap to me. But is the specification right? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Acoustic Report - Window Upgrading Costs... Help? 7Jul 15, 2011 2:48 pm Hi Ed, I am most likely getting my windows and doors from you, I am just trying to get around the delivery since you guys don't come to Adelaide anymore. But in regards to the stacker I was going to get a sliding stacker from you but now I am worried about the air leakage. Is there more leakage from a sliding stacker compared to a normal sliding door? Especially since I am going for a door 3.6m wide X 2.4m high that a lot of area for air to leak through. This is important to me as I have buzzing planes where I am building. Also for the OP Ed does do a acoustic window at a reasonable price, I will be spending that bit extra for my bedroom windows. I think they achieve STC34.5 I'm sure I will be corrected if I am wrong. Aaron Re: Acoustic Report - Window Upgrading Costs... Help? 8Jul 23, 2011 12:24 pm And for those with a bit of cash that are chasing a 44db reduction, have a look here: http://www.doubleglazed.com/windows.html Last paragraph Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7942 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13103 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7552 |
