Browse Forums Windows & Doors 1 Jul 04, 2011 12:36 pm When I planned the wardrobe fitouts for our bedrooms, I discussed with the builder and agreed on 3 sliding panels per wardrobe. I had envisioned a 3-track system where the doors could all be stacked behind one another at one end. What was installed was 2-track framing which means that two panels share one track with the third panel on the other track. We can only ever expose two-thirds of the wardrobe at any one time - a big PITA! Had a better look at the tracks this morning - there is a track along the floor and then a track at the top of the doors so it will be really easy to replace with 3-track framing if it exists. Does anyone know what brand these tracks might be so I can call and see if they have 3-track framing? Top frame: Bottom frame: Re: Sliding Wardrobe Door Headache 2Jul 04, 2011 12:42 pm I don't know what brand they are but you could try calling your builder to ask which company manufactures their sliding robe door systems. Built with RedInk Custom 5000 Key Handover 15/12/2009 Re: Sliding Wardrobe Door Headache 3Jul 04, 2011 1:09 pm Kb, like you I was expecting a three door slider in one room too but they decided to make two quite large mirror doors...who knows why because three would definitely have been a better option. Anyway, I'm sure you can get a three groove track and fairly certain they have this at Bunnings, or otherwise your local shower screen or window manufacturer...that's if your builder (like mine) won't fix it. If your sliders are like mine, they are simply lifted then lowered into position on the track with removal being the reverse. Remove the tracks (screwed in place) replace with new tracks and lift doors into position again. Isn't it a pita when they don't listen...or maybe they do, but instead go ahead and do things the way 'they' want, as opposed to what 'you' want. Re: Sliding Wardrobe Door Headache 4Jul 05, 2011 12:39 am That style of track comes from capral (called magic touch) and is only available in a 2 track design. You eventually get used to what door to open to get what you want. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sliding Wardrobe Door Headache 5Jul 05, 2011 10:07 am chippy That style of track comes from capral (called magic touch) and is only available in a 2 track design. You eventually get used to what door to open to get what you want. Oh no! Exactly what I didn't want to hear!!! Yes, DH said that I am noticing it more because I am unpacking and putting things away in different parts of the same cupboard - down the track it might not be such a PITA, to me anyway. My daughter has to slide the doors one way to access shelves and then the other to access her hanging space - a long term PITA for her! Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3107 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16337 |
