Browse Forums Windows & Doors 1 May 14, 2011 9:15 am Hi, I wandered through my place which is being built and noticed that after the brick cladding went on the stacker door doesn't close properly, with a gap down the bottom unless you really force it. I'm not sure if the image below captures it very well so click here for a higher resolution to see. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Obviously this will need to be fixed. Is it a dud door or is it being squeezed out of square by the bricks, or can that even be discerned from a photo? Is it something that is easier to fix if it's addressed now, during the build? Or can it wait for later (i.e. inspection). Should I nag my SS about it? I hate sliding doors that don't slide smoothly or seal properly. Hopefully this is going to be an easy fix! Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th Re: Stacker door uneven - build 3May 14, 2011 11:13 am DrMatt Hi, I wandered through my place which is being built and noticed that after the brick cladding went on the stacker door doesn't close properly, with a gap down the bottom unless you really force it. I'm not sure if the image below captures it very well so click here for a higher resolution to see. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Obviously this will need to be fixed. Is it a dud door or is it being squeezed out of square by the bricks, or can that even be discerned from a photo? Is it something that is easier to fix if it's addressed now, during the build? Or can it wait for later (i.e. inspection). Should I nag my SS about it? I hate sliding doors that don't slide smoothly or seal properly. Hopefully this is going to be an easy fix! Check the jamb for plumb. It it's plumb then the door will easily be adjusted to suit. If not, let your supervisor know as there may not be enough adjustment. Brickies often lever the doors to suit brickwork, it's not right, but they do it. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Stacker door uneven - build 4May 14, 2011 11:15 am Cheers! Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 5978 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 6423 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 1852 |
