Browse Forums Windows & Doors have a look 21Mar 12, 2008 3:18 pm tehse stacker doors are on display at the JENSEN 36 FROM CARLISLE HOMES. : www.carlislehomes.com.au Re: Stacker Doors 22Mar 20, 2008 9:52 am I'm building at the moment & I wanted exactly what you described. We had to go with a support column between where the two windows converge due to structural issues too. Stackers are apparently cheaper than bi-folds though. I'm not really sure what ours cost, but they were under $4000 I'm positive for a roughly 2.5m one and a roughly 3.5m one.
Then the idiot builder ordered one of the doors to open the opposite way to the plan. They flipped it over but there is a hole in the frame from where screw had been. Hope they can fix it OK, since it was their mistake in the first place. Cheers Toon Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3967 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12380 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7881 |
