Browse Forums Windows & Doors 1 Feb 09, 2011 10:00 pm Looking at having bifold doors leading out to a concrete patio. Looking out of the doors it faces north. We were thinking of having the lounge room floor as being almost seamless out to the patio via the bifold doors. The builder says there is normally a step to an outside area and that it's better to have a big step instead of a small one. He tells me when it storms that water might run back inside the house. So he thinks 100mm is ok. I know there will be a fall on the patio to the garden so the water should drain away from the bifolds but how big a fall is required over a 3800 mm wide patio? We are also going to have a small, about 800mm wide, plastic roof off a pergola over the doors. Would this be enough to keep the rain off the bottom of the door? Storms in sydney usually come from the South. I've seen many patios and bifold doors on the same level as the internal areas. How do people weather proof the internals when there doesn't appear to be a drain along the outside of the door? Re: bifold doors and external levels? 2Feb 10, 2011 5:50 am 1sthome Looking at having bifold doors leading out to a concrete patio. Looking out of the doors it faces north. We were thinking of having the lounge room floor as being almost seamless out to the patio via the bifold doors. The builder says there is normally a step to an outside area and that it's better to have a big step instead of a small one. He tells me when it storms that water might run back inside the house. So he thinks 100mm is ok. I know there will be a fall on the patio to the garden so the water should drain away from the bifolds but how big a fall is required over a 3800 mm wide patio? We are also going to have a small, about 800mm wide, plastic roof off a pergola over the doors. Would this be enough to keep the rain off the bottom of the door? Storms in sydney usually come from the South. I've seen many patios and bifold doors on the same level as the internal areas. How do people weather proof the internals when there doesn't appear to be a drain along the outside of the door? To be level there would have to be a drain set into the ground at the door - Stormtech do one... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: bifold doors and external levels? 3Feb 10, 2011 11:21 am Thanks Ed. Might need to look into those if I'm unsatisfied with the weatherproofing suggestions. The widow people tell me I can have it recessed 38mm so the door is flush with the floor and then to leave a 10-11mm gap between the outside patio tiles and the door for water drainage. They also say to have a 1in 8 or 1 in 9 fall in the outdoor patio tiles. Still worried about weather proofing even if it's on the north side of the house. Re: bifold doors and external levels? 4Feb 15, 2011 8:05 am Here's an example of what's a concern for me: http://images.domain.com.au/img/2011214 ... 214-103103 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ When it rains or you hose/clean your doors the water could go into the house. Now I'm thinking of having a 50mm step down to the outside patio. Is that going to be too much of a trip hazard or should I make it 100mm? Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6350 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10923 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4290 |
