Browse Forums Windows & Doors 1 Jan 31, 2011 9:16 am We are about to start building a second level extension and still trying to decide on windows. The existing windows are painted timber awning. We would like double glazed Upvc or aluminium to avoid painting on a second level. Good ventilation abilities and Insect screens. The four front north facing windows are 2057x 850 and these need to be a single glass pane but still be able to be opened. We were quoted on Upvc tilt and turn but were told they were not available in the size for the front windows. Any ideas? Re: Window Options for second story extension 2Jan 31, 2011 10:43 am graybags We are about to start building a second level extension and still trying to decide on windows. The existing windows are painted timber awning. We would like double glazed Upvc or aluminium to avoid painting on a second level. Good ventilation abilities and Insect screens. The four front north facing windows are 2057x 850 and these need to be a single glass pane but still be able to be opened. We were quoted on Upvc tilt and turn but were told they were not available in the size for the front windows. Any ideas? Sorry can't do that size in PVC Tilt & Turn, but we can in awning and casement... PVC or aluminium or thermally broken aluminium. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window Options for second story extension 3Jan 31, 2011 11:14 am Thanks for the reply, do you have Upvc casement or awning in panoramic? I presume Upvc cost less than than thermally broken Aluminium? Are there any advantages/disadvantages of casement over awning? -Graham Re: Window Options for second story extension 4Jan 31, 2011 12:52 pm graybags Thanks for the reply, do you have Upvc casement or awning in panoramic? I presume Upvc cost less than than thermally broken Aluminium? Are there any advantages/disadvantages of casement over awning? -Graham I don't know what you mean by panoramic? Is that our size chart description? Costs are roughly aluminium 100%, uPVC 140%, commercial aluminium 150% (Takes plaster reveal), thermally broken 170%. But all miles cheaper than the competition. And our aluminium is the most energy efficient in Australia. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window Options for second story extension 5Jan 31, 2011 2:52 pm Yes from your website, awning window panoramic Ecoplus range. I am confused because we had a quotes from Ecoclasic one of them was for tilt and turn Upvc in 2057x850. Was then told was 2057x850 not available in tilt and turn so decided on awning Upvc only to be told cant do Upvc awning in the panoramic even though we had the drawings done with sizes from your website. You might want to look into it. Re: Window Options for second story extension 6Feb 01, 2011 8:47 am graybags Yes from your website, awning window panoramic Ecoplus range. I am confused because we had a quotes from Ecoclasic one of them was for tilt and turn Upvc in 2057x850. Was then told was 2057x850 not available in tilt and turn so decided on awning Upvc only to be told cant do Upvc awning in the panoramic even though we had the drawings done with sizes from your website. You might want to look into it. OK... there must be a misunderstanding. We can make the 2057 x 850 in tilt and turn. Please refer your query/quote to me and I will sort it out. Thanks for your patience. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window Options for second story extension 8Feb 01, 2011 12:25 pm graybags Thanks. Can flywire screens be fitted to tilt and turn? Yes, in a fashion. They only secure way to fit the screens is to face fit onto the front of the window (ugly IMO). Others say to use the pins inside the opening, but they will fail. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8482 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 We are building a second dwelling and are currently selecting window and door frames. We want to blend into the forest and also bring out the stone work and the fake wood… 0 15938 |
