Browse Forums Windows & Doors 1 Jan 07, 2011 10:53 am We are looking at buying some windows off eBay to put into the house we are building but have no idea or what their wind rating is. Does anyone know how to determine this and also how would we go about showing council our conclusions? Re: How do I determine wind rating on second hand windows? 2Jan 09, 2011 8:16 pm im not sure if this applies for the windows your buying, from experience there is 'stamp' on the glass of the window which shows manufacturer and window type. if you can grab that then maybe you might be able to find out. in most cases though its how they are fixed that affects the wind rating eg screw length and number of fixings Re: How do I determine wind rating on second hand windows? 3Jan 09, 2011 10:21 pm tomthechippy im not sure if this applies for the windows your buying, from experience there is 'stamp' on the glass of the window which shows manufacturer and window type. if you can grab that then maybe you might be able to find out. in most cases though its how they are fixed that affects the wind rating eg screw length and number of fixings The stamp is just to identify that the glass is toughened. The wind rating depends on the manufacturer's tests for that product at that size. Identify the manufacturer and ask them... In all cases the window is rated, the fixings have to be appropriate as well. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: How do I determine wind rating on second hand windows? 4Jan 10, 2011 10:40 am Thank you for the help, much appreciated:) Re: How do I determine wind rating on second hand windows? 5Jan 10, 2011 4:01 pm Another thought... check that the windows have stickers showing the rating... likely inside the frame opening. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hi team, Im looking for a second hand sd4b monitor preferably white. 0 8923 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1500 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4488 |
