Browse Forums Windows & Doors 1 Nov 25, 2010 11:29 am I have some door frames to be installed which are stainless steel. They look great however I think the thermal bleed could be an isssue. That is if warm inside and cold outside the frames will conduct the heat out and vice versa. They will be filled with concrete behind the frame that is concrete will fill the hollow of the frame. Will this be an issue? The entire width of the frame is 200mm. Is there anything I could place inside the frame as a thermal break particularly the edge facing into the house (40mm) maybe a strip of foam. Or will the concrete slow the whole process (heat transfer) down anyway? I hope this makes some sense Thanks Pulpo Re: Thermal bleed Stainless steel door jamb 2Nov 25, 2010 4:14 pm Pulpo I have some door frames to be installed which are stainless steel. They look great however I think the thermal bleed could be an isssue. That is if warm inside and cold outside the frames will conduct the heat out and vice versa. They will be filled with concrete behind the frame that is concrete will fill the hollow of the frame. Will this be an issue? The entire width of the frame is 200mm. Is there anything I could place inside the frame as a thermal break particularly the edge facing into the house (40mm) maybe a strip of foam. Or will the concrete slow the whole process (heat transfer) down anyway? I hope this makes some sense Thanks Pulpo Stainless steel is actually a good insulator. The coefficient of heat transfer of stainless steel is 10% of aluminium. So don't worry... that's why s/s mugs of coffee stay hot for ages. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Thermal bleed Stainless steel door jamb 3Dec 05, 2010 9:19 am Many thanks ALthough I think those coffee mugs and thermo flask having stainless steel on the outside is not actually there for insulation more for looks and durability. One thing less for me to worry about. Pulpo Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6780 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14544 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1837 |
