Browse Forums Windows & Doors 1 Nov 23, 2010 9:15 am Hello, We are currently decorating a 1934 weatherboard cottage in Tassie. We just finished painting the bedrooms and we’re up to buying curtains. We have quite high ceilings (about 2.7m high). I would like to make the rooms look really elegant and really show off the high ceilings by hanging the curtains from the start of the wall - right at the top of the wall – and running the curtains the full length of the wall down to the floor. But a thought has crossed my mind: would it look out of place hanging the curtains that high - because the picture rails would be covered by the curtains? Below the picture rail or above it? My blogs: http://www.movingtotasmania.com.au - a resource for those considering relocating to Tasmania http://www.sarahandtim.com - my daily life and renovation blog Re: Curtains mixed with high ceilings and picture rails - w 2Nov 25, 2010 4:48 pm Hi sarahlou2 the height of the curtains depends on a couple of things. Firstly - the look you're after Second - the material you're using. If you are after a grand look (sounds like you are!!) then I'd place them high. See the attached pic for an idea of how this looks. It is very dramatic and elegant and if that's the type of impact you want then go for it!! http://www.gcfaulkner.ie/curtains/1930- ... -home.html Re: Curtains mixed with high ceilings and picture rails - w 3Nov 25, 2010 7:23 pm Picture rails will encourage your eye to focus there, it may seem a little odd in your mind if your drawn to focus into both areas. Aesthetics is a psychology, have you heard of the 'Golden Ratio'? There's heaps of info about it on the net, even a few YouTubes. I suggest you get someone to hold a curtain at the height of the window and at the ceiling ...take a few steps back, then make your decision. Re: Curtains mixed with high ceilings and picture rails - w 4Nov 25, 2010 8:29 pm Hey sarahlou2, There's a few factors to take into consideration... but at the end of the day it comes down to what YOU like best. But if it were me, I would look at hanging the curtains like this: The height of the bottom edge of the pelmet is fixed to line up (or be near enough) with the bottom edge of the architrave - by using a larger pelmet you can give the impression that the window is much taller than it really is, and by leaving part of the wall exposed above the pelmet you can actually create a greater sense of space and height - by having the curtains go right the way up, you may in fact close the space in as the eye will be drawn to one unbroken line from floor to ceiling. Re: Curtains mixed with high ceilings and picture rails - w 5Nov 25, 2010 8:58 pm Assuming sarahlou2's picture rail is like you have demonstrated... that'll look great Ikon (calculate distances between ceiling, pelmet and picture rail) ...Golden Ratio. Re: Curtains mixed with high ceilings and picture rails - w 6Dec 09, 2010 7:24 am Well, thanks for all the replies\ I had no idea that anyone had replied *must check the box that says 'notify me of replies'* Ikon, thanks for the great diagrams there. Unfortunately my picture rail goes around the room, unbroken, about 10cm above the window. Hope you don't mind, I've taken the liberty of canibilising your diagram ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So now you can see my dilemma about where exactly to position the curtains. On the one hand, it would be so lovely to take advantage of our 3m high ceilings by having floor to ceiling curtains [and have the picture rail poking out from underneath the curtains], but on the other hand it may be less weird to simply position the curtains just underneath the picture rail and above the window so that the picture rail remains unbroken. But then again, it might be nice to have that harsh line of picture rail broken up a tad. And then again, like theOK says, is the eye going to be drawn to that section of picture rail in the centre of the curtains - aaaaaaaaarrrrrrrgggggghhhhh!! One thing I know for sure is that I'm going to make my own thermal lined eyelet curtains. My blogs: http://www.movingtotasmania.com.au - a resource for those considering relocating to Tasmania http://www.sarahandtim.com - my daily life and renovation blog Re: Curtains mixed with high ceilings and picture rails - w 8Dec 21, 2010 4:03 pm Hi Ikon, I had originally written off the idea of having a pelmet but it does make perfect sense in my scenario to have a pelmet. Thanks so much for your suggestions - and to everyone else too! My blogs: http://www.movingtotasmania.com.au - a resource for those considering relocating to Tasmania http://www.sarahandtim.com - my daily life and renovation blog A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6740 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39755 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7343 |
