Browse Forums Windows & Doors 1 Oct 20, 2010 4:42 pm Does anybody have any experience in fitting the woven aluminium security screens like crimsafe and amplimesh into uPVC frames? The best answer I've been able to get locally is "I'm not sure, but I think you could screw it into the steel bar that runs through the upvc frame..." In our case while the additional security is welcome it is primarily because of its pet-proof properties: it can't be harmed by our cats and will allow us to swing tilt-and-turn windows right open. I should add, that the two major supplies here use either Deceuninck or Kömmerling. Re: uPVC windows and Crimsafe / Amplimesh screens 2Oct 20, 2010 5:53 pm As you have tilt & turn windows, the only way to get what you want is to screw the screen onto the face of the window. If you are trying to prevent pet damage, then normal flyscreens with stainless mesh would be enough - and much cheaper. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: uPVC windows and Crimsafe / Amplimesh screens 3Oct 22, 2010 9:49 pm Hi, In Bunnings you should be able to buy some white plugs and you can fit your flyscreens without screwing, and you will be able to take it out of the window, clean it and fit it back at will. They are not expensive and can be a good alternative to screwing if you don't like that idea. Email me for details, I can help out with a few instructions if you are inclined to do it yourself. Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: uPVC windows and Crimsafe / Amplimesh screens 4Nov 04, 2010 11:25 am Okay, no simple answer for this one as there are a couple of variables. By way of background, we are a uPVC fabricator (Deceuninck profile) and a Bradnams aluminium fabricator and commercial aluminium fabricator. To complement our uPVC suite, we use the Supa Screen security product in the following applications. (Supa Screen is a similar product to Crimsafe) * Sliding security doors. We use an intergated track that perfectly complements the aesthetics of the sliding door profile. * Hinged Security doors. We developed a spacer profile that colour matches the door profile and allows normal installation. * Windows, both inward opening and outward opening. We use our proprietory product screen profile that fits within the uPVC frame and only protrudes 2mm from the window face. For flyscreens we use stainless steel plunger pins for easy removal. For security mesh, we also fit tamper proof fixings. This screen profile is also wrapped in our standard uPVC vinyl colour range for excellent aesthetics all round. This allows for perfect matching of golden oak and other woodgrain selections as well as every other colour. Just be mindful that using turn buttons are only fine for insect mesh as they offer no real security and dont look the best IMHO. Feel free to PM me if you would like me to send you a picture of how we screen our windows. Cheers and good luck, Brad Depends... Brick veneer required the window to be attached to the house frame, this is usually achieved by screwing through the timber reveal into the frame. There are… 1 4603 Hi Simeon, Thanks for your reply. Yes, that makes sense. I contacted the manufacturer; they will issue a certificate with BAL rating mentioned on it. 2 1845 Hi everyone. I am a single mother with little daughter, living in a small tourist town in WA Australia. I am thinking to install security screens to all the doors and… 0 12695 |
