Browse Forums Windows & Doors Re: Different heights for Internal door and openings - Is it 6Oct 12, 2010 9:34 am Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Different heights for Internal door and openings - Is it 7Oct 13, 2010 6:53 pm I've seen this with door frames next to each other, where one opens out and one in, the height difference caused by the door stop thickness. It looks terrible, and should be rectified by the installer at initial install of frames IMHO. Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6559 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 12077 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5284 |
