I feel a bit stupid asking this....but can anyone describe how to lock/unlock an A&L aluminum sliding window? I put the key in and it turns half way, but I still can't seem to slide the window open. Is there a trick to lifting the lock section up or down, or to one side....I'm clueless here. The section with the lock in it seems to move around a bit. I haven't had sliding-window locks before. Should the key be able to turn a full circle, or just half way?
edited: resolved now! thanks. The key turns half way, then the lock section has to be pulled out/tilted towards you and then to the side you are sliding
