Browse Forums Windows & Doors 1 Sep 09, 2010 9:21 am I have a linen press that need to have a door re-hinged. Can anyone tell me looking at the pics below what sort of hinges this would require - due to the nature of the door and the frame standard door hinges will not work. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8289 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6348 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16126 |
