-29 BAL Windows
Page 1 of 2
I have a couple of questions if anyone can answer with some experience in this area. Trend windows advertise their bush fire rated windows as such, but just wondering if they are the only ones we are able to use? Just had the quote back from them and almost fell off the chair as our house design has a lot of glass.
Also some window manufacturers request a window schedule whereas our building designer says any manufacturer worth their salt should be able to work from plans. Do I need the added expense of a window schedule for quotes assuming I can use someone other than Trend?
No window manufacturer needs a window shedule however it takes out any room for error. You dont need one. just tell them the windows are "as per the plan".
It's pretty disturbing though that there isn't any competition in this market. So everyone in a bush fire zone uses either Trend windows or shutters? Unfortunately shutters won't work in the design of our house - the windows extend all the way to the pitched roof.
as additional food for thought, some steel-reinforced uPVC windows are rated to BAL 29. So that covers fire compliance as well as excellent thermal performance. Let me know if you would like any more details/reports etc.
Cheers,
Brad
SOots
Hi We are a bal 40 in victoria it states that the windows need to be 5mm toughened glass with screens bronze or steel 2mm thick , we were getting roller shutters with ordinary windows but they are not rated yet so they now have to come and replace the glass in the windows
SOots
SOots
Make sure the screens supplied cover both fixed & opening sashes.
NOT happy about the screens they have installed on my doors (the widows aren't up yet). They are basically normal flyscreens but made of flimsy metal/mesh. I thought they would have to be quite solid- I was thinking more like the crimsafe metal. I need to find out what they are supposed to be like so I can make sure I am not being ripped off.
We have the 5mm toughened gIass and also the screens as well- But I have just been up to my house this morning and I am We have the 5mm toughened gIass and also the screens as well- But I have just been up to my house this morning and I am NOT happy about the screens they have installed on my doors (the widows aren't up yet). They are basically normal flyscreens but made of flimsy metal/mesh. I thought they would have to be quite solid- I was thinking more like the crimsafe metal. I need to find out what they are supposed to be like so I can make sure I am not being ripped off.
Hi LJ I am pretty sure the screens and doors need to be 2mm thick steel or bronze screens not the ordinary fly screen on all windows and doors
Tammy
Hi LJ - sounds concerning. I'm finding these BAL regulations a minefield and we're just in the quoting stage. .
I'm hearing you! And trying to get information today has just been a nightmare, everyone condradicts each other in their information.
One says to me ******* aluminium mesh is fire safe- how that is possible I do not know, then someone else tells me no-it should be 2mm steel mesh like what Sooty May said. It's just nuts. Even ringing the actual building commision- the person there did not have a clue!
The screens referred to are - 'a mesh with a maximum aperature of 2mm, made of corrosion - resistant steel or bronze.'
thanks heaps Tammy
With doors - 6mm toughened glass & where the glazing is less than 400mm above ground level, decking etc screened.
Doorframes to be metal.
Weather strips or draught seals installed.
Under the current legislation - which will undoubtably be revised in the next BCA - flyscreens to both fixed & openable.
thanks ausdesign for your help will keep an eye on things
3
Thank you it really does, appreciate your response!
22/05/2023
7
Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.…
