Hi,
does anybody has uPVC windows installed with VEKA profiles and what is your experience? Are they similar to Kömmerling in terms of quality? VEKA is a German profile.
Browse Forums Windows & Doors Re: VEKA profile for double glazed windows/door 2Aug 18, 2010 7:52 am Evelin Hi, does anybody has uPVC windows installed with VEKA profiles and what is your experience? Are they similar to Kömmerling in terms of quality? VEKA is a German profile. Very good well known brand... yes, it's the same quality as Kommerling/Rehau etc. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: VEKA profile for double glazed windows/door 3Aug 19, 2010 4:43 pm ed @ EcoClassic Evelin Hi, does anybody has uPVC windows installed with VEKA profiles and what is your experience? Are they similar to Kömmerling in terms of quality? VEKA is a German profile. Very good well known brand... yes, it's the same quality as Kommerling/Rehau etc. Ed Thanks Ed. What I also would like to know if it possible to change the window handles to a brand other than what the windows installer uses usually. Re: VEKA profile for double glazed windows/door 4Aug 19, 2010 7:42 pm Evelin ed @ EcoClassic Evelin Hi, does anybody has uPVC windows installed with VEKA profiles and what is your experience? Are they similar to Kömmerling in terms of quality? VEKA is a German profile. Very good well known brand... yes, it's the same quality as Kommerling/Rehau etc. Ed Thanks Ed. What I also would like to know if it possible to change the window handles to a brand other than what the windows installer uses usually. Generally no. They either form part of the total hardware, or the holes and cutouts are suited to only that brand. But ask, they may offer a choice. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: VEKA profile for double glazed windows/door 5Aug 26, 2010 1:06 pm Hi, When comparing profiles it can be useful to ask where the profile is actually made - the company may very well be German, but do they extrude in China, in Turkey, in Germany? Then you must decide what you are prepared to accept and whether you are convinced that the quality will be retained regardless of where the profile (or even windows) are actually made. One way to compare quality from a technical perspective is to inquire about the performance of windows under test conditions for UV weathering, sound insulation etc. Hope this helps. Cheers, I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16235 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
