Browse Forums Windows & Doors 1 Aug 16, 2010 8:16 am We've decided to close in under our new stairs, and the builder has put up a frame and installed 3 'push latch' doors. Given the need for custom-fit doors to match the angle of the stairs, they've used what appears to be chipboard flooring...it's a little ugly, very heavy, and seems to be straining the hinges somewhat. Can anyone suggest if using flooring is considered ok for doors, or are we asking for trouble in the long term? What else could/should have been used? Re: Which material for custom doors under stairs? 2Aug 16, 2010 10:17 am I think just get a door (cheap plain one) and cut it back, cover the cut with something. Fill in the gaps, sand back and paint. May want to ask a chippie. Different to what others have said but thanks for that insight. 2 5201 Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10591 |
