Browse Forums Windows & Doors 1 Nov 05, 2007 9:55 pm Hi guys,
I wonder if a door expert can give me some advice here. A few of the doors in my house have a easily identifiable criss cross pattern showing throught the paint. It is obviously the core of the door. On some of the doors it is not noticable at all but on others it really stands out. Carlsisle Homes are looking into the issue for me but I would like to know if it is a manufacturing issue, a painting issue or a non issue... Any help is appreciated. Re: Corinthian Doors - possible problem... 2Nov 05, 2007 10:36 pm Does it show up in photos, can you show us?
Obviously a light sand isn't gping to fix it then? Corinthian are pretty good i would think. Hopefully you can get replacement doors and all is well. ![]() ![]() Re: Corinthian Doors - possible problem... 3Nov 07, 2007 9:14 am Have you tried ringing them Matt, ask them the questions of what is the reasoning for this to show up... Also is it just a single criss cross - as in what some one might put on the door if it has faults compared to the norm?
Or is it more grain orientated that is just showing up because Carlsile hasn't prepeared the timber door properly.. ![]() PS I also know I spelt Carlsile wrong, this way no asterixs ****.... ![]() Gav & Vanessa Building In Melbourne (Sth East Suburbs) http://www.arkraider.blogspot.com/ Rawdon Hill Construction - Canterbury Heritage Re: Corinthian Doors - possible problem... 4Nov 07, 2007 10:25 am Hey Matt, i think i understand what you mean with the doors. We went through some more display homes yesterday and one of them had a door with the criss cross pattern that i think you are refering to....
Being the pedantic people that we are, hubby called me over to check it out and said that it was the internal re-inforcement showing through the outer panels of the door and that could be a fault with their assembly process..... possibly being pressed too tightly on the door's cardboard honeycomb like skeleton. Of course then i told him about your problem and he mentioned it "might" be the same thing - without looking at them of course. Forgetting about the size for now, a detention tank is applicable to a Premissable Site Discharge (PSD) flow rate, the very reason for their requirement. Check with the… 6 2620 ![]() yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 2721 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 8350 ![]() |
