ahaaaaaa.........someone agrees with me
Browse Forums Windows & Doors Re: Changing Our Painted Entry Door to Stained Timber 21Aug 03, 2010 6:15 pm to_do_list The color at the moment is "lost" in the surrounding color scheme...in my opinion. ahaaaaaa.........someone agrees with me Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Our Painted Entry Door to Stained Timber 22Aug 03, 2010 7:33 pm if you end up not being able to change to a stained timber (which does sound gorgeous) someone else had a gloss black door that truly popped - that might work for your place, too. Re: Changing Our Painted Entry Door to Stained Timber 23Aug 03, 2010 7:42 pm thanks sweetime ............I've got a lot to consider. Nothing with this build was easy It just makes me sooo mad that because I didn't think through the architrave issue way back when, I'm now unable to finish what I originally wanted Another 'oh well' moment . Far too many with this build, as far as I'm concerned !!!!!!!!!!!! Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Our Painted Entry Door to Stained Timber 24Aug 03, 2010 8:39 pm Funny you should bring this up Southies - We have the same dilema. I have double entry doors that I want changed to timber and we also have painted door frame. No idea what we are going to do but I will get my timber doors!! My karma ran over your dogma Re: Changing Our Painted Entry Door to Stained Timber 25Aug 03, 2010 10:19 pm In that case bel I'll will hold off on a decision until you resolve your doors . I want to see 1st how yours work out Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Our Painted Entry Door to Stained Timber 27Aug 06, 2010 12:43 am Southies, as promised here are 2 pics of our front door for you to see... We have 'white lustre' aluminium window frames (sort of a pearl white), and the door frames are painted gloss white. Gutters and fascia is Monument and roof tiles are Graphite (dark grey) if that makes a difference. The handle on there is just the dummy builders handle. We'll be having Gainsborough tri-lock lever and dummy set in satin. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oceanic with Nautilus upgrades. Handover 8 September 2010 Re: Changing Our Painted Entry Door to Stained Timber 28Aug 06, 2010 7:17 am Many, many thanks Oceanus2 ! I see how your architraves tie in with your facade. They match your window frames Yours work! I don't think mine will, as our window frames are in white birch & not jasper I'm thinking that this post-handover task is a no-goer afterall. I could kick myself for not thinking about the architraves when I had the chance Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Our Painted Entry Door to Stained Timber 32Aug 10, 2010 2:46 pm Apart from the general response on this thread that I shouldn't change my painted door to a stained timber door , it seems the cost is prohibitve anyway . THe big C door company, quoted $1200 to supply the exact same door in a rosewood veneer on an MDF substrate - what utter rubbish !!!! That definitely 'puts a nail in the coffin' of changing the door Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Changing Our Painted Entry Door to Stained Timber 33Aug 11, 2010 8:10 pm I love your facade Southies and your front door was my inspiration to choose Jasper as well!! I love my front door (even though it still has only one coat of paint on it!!) Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11383 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5540 |
