Browse Forums Windows & Doors 1 Aug 02, 2010 12:07 pm hi I'm wondering if I should get Bradnams (the window supplier) to tint my windows from the factory or to get an aftermarket film tint? The guy at bradnams said they impregnate the glass with the tint and told me the aftermarket always has the risk of peeling off. Bradnams use a product called "Solar Block" thanks, Daniel. Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: should I get factory window tinting or aftermarket tinti 2Aug 02, 2010 12:24 pm danrts hi I'm wondering if I should get Bradnams (the window supplier) to tint my windows from the factory or to get an aftermarket film tint? The guy at bradnams said they impregnate the glass with the tint and told me the aftermarket always has the risk of peeling off. Bradnams use a product called "Solar Block" thanks, Daniel. If you are positive you want it, get the factory fitted stuff, then you can't damage it by cleaning it. If you are not sure, then try clear glass first. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: should I get factory window tinting or aftermarket tinti 4Aug 04, 2010 7:52 pm Gone through the same dilemma! In the end we went for clear glass since the builder only supplies glass that is ever so slightly tinted which wasn't enough . The other downside is that film tinting is much more exy My signature is distracting people from my wise posts ... Re: should I get factory window tinting or aftermarket tinti 5Aug 05, 2010 9:13 am On this subject, can anyone recommend brands of film or particular contractors for tinting around Melbourne? I will need one or two windows done which are almost west facing. I really want to stop the UV without those windows looking too different from the rest of the house (i.e. won't look like 2 silver windows from the outside!). Re: should I get factory window tinting or aftermarket tinti 6Aug 06, 2010 2:45 pm I'm in Qld, we definately get Solar Block from Bradnams here! http://www.bradnams.com.au/files/BDM_Solar_Block.pdf Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: should I get factory window tinting or aftermarket tinti 7Aug 13, 2010 8:29 pm Ah right, I must not have been searching very hard. I can't find more detailed specs but the ones on the brochure don't really compare to an aftermarket film SOLAR BLOCK Heat 32% Glare 78% UV 26% Llumar SP70LIR Heat 73% Glare 93% UV 99.9% Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6338 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12647 9 24751 |
