Browse Forums Windows & Doors 1 Jul 28, 2010 2:47 am Hi All, Was just wondering if anyone knows whether there is a huge difference in the quality of blinds between Luxaflex and Peter Meyers. I just got quotes from them and the price difference is huge. One in the $20K range the other around $9k. Are there any other good blind companies to deal with. I have to confess for one of the companies I was made to feel as if I was a waste of time as I wasn't a designer. I am after good quality mechanisms. Thanks in advance. Re: Blinds - Different brands 2Jul 28, 2010 9:54 am Can't help you with the actual companies but from my experience you need to make sure that you are comparing apples with apples. When we had our quotes done it worked out really well as all 3 companies used the same fabrics so I chose the same from each. Then the only difference was the chain mechanisms - which they all had samples of so I could have a look and feel. So just make sure that you specify pretty much identical from each company as fabric differences alone can cause a massive difference in prices. Some things are worth waiting for. Thank you fro your response, Simeon. It is good to hear that you have had a positive experience with Parisi. I am always on the lookout for reliable products, and personal… 2 4347 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6352 |
