Browse Forums Windows & Doors 1 Jul 19, 2010 7:16 pm hi I'm wanting to put a double door over the opening to my rumpus room. The opening is 2400mm high x 3000mm wide I understand at 2400mm high cavity sliders can be a problem with bowing etc, and I'm not sure about 2400 x 1500 cavity sliders either Does anyone have any ideas? thanks Daniel. Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: double sliding doors for 2400 x 3000 opening? 2Jul 19, 2010 8:49 pm I certainly hope 2400 mm high cavity sliders don't bow, since that's what I'm getting. having said that, the widths are only 920 mm each. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: double sliding doors for 2400 x 3000 opening? 3Jul 19, 2010 11:44 pm not sure if it's just a problem living in the tropics but several builders have cautioned me against 2400 high cavity sliders. for some reason 2100 high cavity sliders seem to be ok Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: double sliding doors for 2400 x 3000 opening? 4Jul 20, 2010 1:10 pm Can't see why the extra 300 mm would make a big differnce. If you are really worried, what about putting in an metal angle (actually a T-piece) into the far end of the door. This would provide some bracing that should certainly take a 2400 mm high door beyond the performance of a 2100 mm high door. Oh, and make sure the door is sealed and painted on all six faces. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: double sliding doors for 2400 x 3000 opening? 5Jul 20, 2010 8:49 pm We have 2400h x 3600w stacker doors, we had to get an engineered beam put in to support the wieght of the doors, they are heavier than the 2100h stacter doors we have. The door was attached in several place at the top into the beam. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16161 we have a standard size and often we have a lot of variety to choose 0 3578 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5044 |
