door frame rotting at base
IF THE ROT IS NOT TO BAD AND IS GOING TO BE PAINTED OVER BY A SOLID COVER PAINT REMOVE THE ROT SO YOU GET BACK TO HARD TIMBER THEN TREAT THIS AREA WITH A WATER REPELLANT LIKE BLUE 7 FILL THE HOLE WITH BUILDERS BOG (MAKE SURE YOU DONT GO OVERBOARD WITH THE BUILDERS BOG THIS IS HARD STUFF TO SAND BACK. WHEN YOU HAVE DONE THAT PRIME AND REPAINT.
IF YOU HAVE BAD ROT OR YOU WANT TO TO STAIN/OIL THE DOOR THE BOTTOM PIECE OF TIMBER HAS TO BE REPLACED AS THE STAIN WILL SHOW THE FILLER AND WILL NOT LOOK TO GOOD
TO THOSE WHO ARE PAINTING DOORS IT IS VERY IMPORTANT TO PAINT THE TOP AND BOTTOM OF THE DOOR AS THE MOISTURE GOES UP/DOWN AND MAKES THE PAINT PEEL AND OR WOOD ROT.
ALL THE BEST
EGGENZ 2004
1
You will need to replace the entire stairs. Carpenter is the trade you're after.
18/04/2024
8
This is 100% true. You can not hang anything on steel frames. very frustrating
20/07/2023
Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks
