Browse Forums Windows & Doors 1 Jul 12, 2010 12:00 pm Hi All, I am looking at changing my entrance door handle to my unit. I am limited in that i need to keep the external handle (a gold knob) on the outside, however internally am looking to change to a chrome lever. Currently internally there is a gold lever which has a push button to activate the lock. My question is: Can I simply change the internal lever over - and ideally i would like to change to a turn switch to activate the lock instead of a push button. Can this work or are the 2 mechanisms to activate the lock different processes? push as opposed to turn? Is this feasible? Or should I be speaking to a locksmith? Or am I dreaming? TIA Re: Door Handle - Change knob to lever (with lock?) 2Jul 12, 2010 1:45 pm what brand of lock do you currently have? "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: Door Handle - Change knob to lever (with lock?) 4Jul 12, 2010 2:26 pm hmmm, makes it hard. need to find out the size of the cutouts. most are fairly standard but can't be sure without knowing exactly what it is. you might need to post a photo or have a good look around. if you can post a pic, i can see if i know it. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6328 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 8981 1 4664 |
