Browse Forums Windows & Doors Re: Window info from Trend 21Nov 02, 2007 8:24 am Hi Casa2,
if you are serious about quality windows with real quality hardware and real value for your money you should look at www.christoffel.com.au Christoffel Pty Ltd. Unit 4/Edward Street Riverstone NSW 276 Tel.: (02) 9627 4811 Fax: (02) 9627 4345 Re: Window info from Trend 22Nov 02, 2007 8:40 am windowexpert,
Thanks for the info. I saw Christoffel doors at the home show earlier this year and I didn't like the appearance. Too bulky looking for me. Also, I like the idea of anodised aluminium and Christoffel only do PVC. However, all that said, I think they're worth a visit and I'll tell them about my requirements and see what they come up with. The worse they can say is "can't do". Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Window info from Trend 23Nov 02, 2007 8:56 am Casa
remember windows are a "continuation "of the wall. What you call "bulky" is the structural integrity of the frames and sashes in order to achive a high performance and to accommodate quality mulipoint locking hardware. If you use those flimsy Aluminium frames you create weak areas in your external walls and even with double glazing you can't achive the same thermal performance as the Christoffel type joinery. Aluminium=big power bills and condensation Ask for the Rhenocoll spraypaint system if you want an Aluminium look outside. It is like powder coating. Good luck! Re: Window info from Trend 24Nov 02, 2007 11:23 am windowexpert,
I'n not after the aluminium look, but rather ultra low maintenance. I'm even going for face bricks rather than render even though it doesn't look as good. To me, if you use bricks (face bricks), glass and anodized aluminium to build a house then even if you come back 1000 years later it will still be roughly the same. Now that's my idea of ultra low maintenance. Anyway, with regards to windows, I would like anodized aluminium because it doesn't deteriorate, unless you live near the sea, which is not the case for me. Can the Rhenocoll spray painting system go onto PVC? Thanks for your continuing help. Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Window info from Trend 25Nov 02, 2007 12:33 pm The Rhenocoll is specifically made for PVCu and it comes with 15 year warranty. It does not peal off !!
Check www.rhenocoll.de/en Re: Window info from Trend 26Nov 02, 2007 3:33 pm ![]() Casa remember windows are a "continuation "of the wall. What you call "bulky" is the structural integrity of the frames and sashes in order to achive a high performance and to accommodate quality mulipoint locking hardware. If you use those flimsy Aluminium frames you create weak areas in your external walls and even with double glazing you can't achive the same thermal performance as the Christoffel type joinery. Aluminium=big power bills and condensation Ask for the Rhenocoll spraypaint system if you want an Aluminium look outside. It is like powder coating. Good luck! Window expert I agree you cannot achieve the same thermal performance as the Christoffel or similar extremely high priced windows. But do we need them? For most people affordability is a huge issue. In a climate such as Melbourne by purchasing high cost say tilt and turn windows with D/G Low e glass with argon you will save NO MORE THAN $250 per year on your heating bill. That is a fact that cannot be disputed. By changing from single glazed std aluminium with 4mm glass to std aluminium with double glazing Low e with argon you will save around $160-$180 and you will save a fortune in the purchase of the product. Aluminium with a thermal break save a few extra bucks but a thicker section. It is a myth in Melbourne and Sydney of massive savings. The key to good thermal performance is a combination of factors including Insulation (wall R 2.0 with reflective foil ceiling 5.0) Concrete slab - say 100mm correct orientation of home good sealing and if possible ability to close off area Etc - the list goes on and can be found simply on the web. And of course thermally efficient windows that are affordable. I agree in some alpine regions and Canberra the saving are likely to be greater Most of these windows designed in Europe where a smaller window area is used in the whole home and smaller windows. As well as the cost of the double glazed windows in Australia it will cost more to install them in your home as the weight of the product will result in the Frame being installed followed by the sash. You need minimum of two people sometimes four. You need mechanical lifting devices. You can achieve great comfort in your home at a reasonable price with aluminium and with the above common sense building rule achieve easily over a 6 star home and on some modeling i am doing 7 star in relation to the multi locking hardware. I do not wish to be locked in my home in the event of an emergency. If someone want to break in multi locking will not stop them. I have found a dog one of the best options to protect your home (and he even wags his tail) Its good to see you back on the forum and please keep posting as we must always challenge the current thinking. DQQ Never argue with an idiot!!!! They drag you down to their level then beat you with experience. Re: Window info from Trend 27Nov 02, 2007 3:38 pm ![]() Hey Casa Sorry did miss the post. This is certainly not the type of work I would normally look at (for a number of reasons) and would likely cost a fair bit. Sorry I cant really be of further assistance on this but if you get someone in NSW to do (i have factories in Qld, Vic and SA) I am happy to review your quote to make sure you are not getting ripped off Good luck DQQ DQQ, Would something like I'm after be available in Melbourne? That is, could you supply? Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Window info from Trend 28Nov 02, 2007 3:51 pm DQQ
I agree that the cost difference between high quality windows and "standard' aluminium windows is high in Australia. In New Zealand the gap is already much closer. With the introduction of mandatory double glazing in NZ it will be almost equal and on longer term the aluminium windows will be more expansive as they need to upgrade their frames to fit the double glazing and thermal breaks. I don't agree that Melbourne is not cold enough to justify thermally efficient windows. I was there myself in June and it was freezing cold inside the houses. Also you can't always look from the cost point or do you buy the cheapest and most economic car? With windows you also need to consider comfort and security. The beauty about the multipoint locking systems is that it provides security and at the same time you are never "trapped" in case of an emergeny like you would with the push locks and "security" stays that come with the aluminium windows. Re: Window info from Trend 29Nov 03, 2007 12:41 am I'm with DQQ .
Having lived in a house in Sweden for 2 weeks with minus 20 degrees outside and 19 to 20's inside - it had triple glazing and superb insulation - it works - but the snow was stacked up and constantly falling - and in OZ - most of us just don't see those sort of climes. I'm all for building and designing a house that is - the most thermally efficient for it's common weather patterns that makes it comfortable to live in on 98 % of the days. For he really bad days - which are generally few and short lived in OZ - you pull the curtains - be a bit more concious of keeping the heat in and or the heat out as is the case in summer. Now Adelaide is possibly a bit nicer than melbourne in winter - but I only lit a fire 4 times last year and the rest - I lived without heating of any kind and being mid renos' about 2 square metres of exposed bricks where I have removed plasterboard in sections - yet the house was constantly 5 to 6 degrees warmer than the outside temp. I have a thermometer inside and out measuring this. And that temp's with 30 year old alu window, single glazing with drafts running everywhere. So we need to keep it in perspective. The lowest temp I measured inside was 7 degrees at 7am and it was often around 11 degrees in the afternoon when I got home in mid winter. Steve Re: Window info from Trend 30Nov 03, 2007 8:16 am Yak-Chat
you wrote "The lowest temp I measured inside was 7 degrees at 7am and it was often around 11 degrees in the afternoon when I got home in mid winter. Well if you find such temperatures acceptable at any given time, any discussion about thermal efficiency is waste of time. ![]() The WHO recommends a minimum inside temperature of 18* C in order to maintain a healthy environment in the house. For myself I find temperatures under 15*C unacceptable at any time day or night summer or winter. If you wonder why houses in Oz and NZ tend to be colder than in Europe, despite the much warmer climate. The answer is simple the standard of housing is 30 years behind the rest of the developed world. In NZ we are in the process of catching up (compulsary double glazing from next year in all residential buildings in the whole country, better insulation standards and more energy efficient heating is also on the agenda...) There is hope for warmer and healthier homes ![]() Re: Window info from Trend 31Nov 03, 2007 9:49 am Quote: you wrote "The lowest temp I measured inside was 7 degrees at 7am and it was often around 11 degrees in the afternoon when I got home in mid winter. I didn't say it was acceptable ![]() I monitored it to see how good/bad this house is before I start to really implmnet some warming methods and heat loss systems such as double glazing. But given that that was the worst I experienced in a house in southern Australian climes that had many sections semi open to the outdoors and with single glazing - it shows we do not have a bad climate in most of oz. NZ - very different and congratulations to your very forward thinking government. Next year in my place, with some double glazing, heavy curtains, and other systems I'll be designing and putting in - I intend to have 18's to 20's inside in winter, with the majority of it being provided by solar energy. We are on the same track. Just used my non heated place as an example. FYI last summer we had several 40 and 42 degree days and the highest the inside temp got in my downstairs section was 29 degrees. Again double glazing would have helped to reduce the heat gain into the house via the warm air on the glass. Steve Re: Window info from Trend 32Nov 03, 2007 1:52 pm In simplistic terms I found a good way to explain double glazing for myself. I can compare it to a stainless steel coffee mug (the type you take camping).
Fill a stainless steel mug with boiling water, after two minutes or less it will be too hot to hold. Now buy a double wall stainless mug (I think they cost about $70 for the nice ones) and fill that with boiling water, a whole difference - you will most definitely be able to hold it, of course for a drink you'd have to add coffee & milk! What are opinions on verandas around the house. We're planning on having them all round at least 1.5m wide. I know it's a huge advantage in summer but unsure if it would stop the nice warmth from the sun in the winter? Re: Window info from Trend 33Nov 03, 2007 3:39 pm Pebbles, a good analagy indeed ![]() Yes verandahs all round do cut down the winter warmth. So design the roof line at the right angles on the northen side (and eastern) to allow the low winter sun to enter and hit the windows of the house in winter, and not in summer. Another way to retro fit a house with all roaudn verandahs is to put clear polycarp sheets in parts of the verandah roof (above house windows) and this allows the sun and light into the house and then put some shades up under the poly carb in summer to keep it cooler. Steve Re: Window info from Trend 34Nov 04, 2007 10:12 am ![]() Another way to retro fit a house with all roaudn verandahs is to put clear polycarp sheets in parts of the verandah roof (above house windows) and this allows the sun and light into the house and then put some shades up under the poly carb in summer to keep it cooler. Steve I think this sounds like a great idea. It would allow us to assess how much sunlight is coming in throughout the year and install the poly sheets accordingly. I can't wait until we move, it will be much easier to consider everything once I see the block in person! Re: Window info from Trend 35Nov 05, 2007 8:47 pm You can do it pre building it - by reading this thread and also using the link that cookie posted there a few months ago.
http://forum.homeone.com.au/viewtopic.php?p=13515 http://www1.sedo.energy.wa.gov.au/pages/windows.asp Casa - I can't find your sun angle calculator - can you repost it. ![]() Pebbles - These will help you see the sun angles you'll experience and then you can plan where the polycarp sheets will be required before you move in. Steve Re: Window info from Trend 36Nov 05, 2007 11:27 pm You can get the solar charts from:
http://solardat.uoregon.edu/SunChartProgram.html For Sydney: Lat: -34 Long: 151 Time zone: UTC +10h Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Hi Everyone, Does anybody have any recent experience building with Trend Connection Homes ? Planning to build a 25 sq split home with them at Campbeltown and reaching… 0 2282 8 14428 ![]() How about some decorative film on the window? Will still let light in but obstruct the view of the fence 3 4827 ![]() |
