Browse Forums Windows & Doors 1 May 14, 2010 9:11 am We'll be building about 800m to 1000m to the ocean and I just love timber framed windows. Our friends told us to go with the plastic they seem to be using in Germany for quite some time but I really like timber. Can someone please tell me if timber is any good when we're so close to the sea??? Thank you so much in advance!!!! Regards, Mel Re: Close to the beach, can I still use timber for windows? 2May 14, 2010 9:29 am Timber is fine, just remember that the clear or paint you use is going to degrade quicker so you will need to do more maintenance more often than a house far from the ocean. Research the coating you are going to use and make sure it can withstand the conditions. Marine grade clears are the best way to go. If you are going to paint the wood, then maybe think about not using wood, that way you don’t need as much maintenance. Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4743 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9617 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 |
