Browse Forums Windows & Doors Re: Flyscreens for louvre windows - internal or external? 2Mar 14, 2010 8:37 pm How would they be fitted to the outside? Unless you never want to open your window. Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Flyscreens for louvre windows - internal or external? 3Mar 14, 2010 8:41 pm GSK How would they be fitted to the outside? Unless you never want to open your window. My understanding is that there would be a separate track to the flyscreen and the louvre blades will not touch the flyscreens when open. Re: Flyscreens for louvre windows - internal or external? 4Mar 14, 2010 8:53 pm I had this same problem with regard to louvre windows. On the outside the outside won't look as nice. On the inside the inside won't look as nice and dead bugs will be on the window sill. In the ned I resolved it by ... going to awning windows. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Flyscreens for louvre windows - internal or external? 5Mar 15, 2010 5:47 am There on the outside, the frame is slightly wider than the louvers so the screen sits there Landscape Design & Construction http://cherub.squarespace.com/ Re: Flyscreens for louvre windows - internal or external? 7Mar 16, 2010 2:56 pm We had the same issue with the louvres we wanted, so we changed them to fixed windows. Found this: http://www.vantagealuminium.com.au/louvre/flyscreen.htm Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5417 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7945 3 10220 |
