I have two square awning windows in my splashback. Is it possible to change these to louvres? If so, would it be a nightmare or relatively simple?
Thanks!
Browse Forums Windows & Doors Re: Changing existing windows to louvres?? 2Feb 26, 2010 10:35 pm JJ13 I have two square awning windows in my splashback. Is it possible to change these to louvres? If so, would it be a nightmare or relatively simple? Thanks! Depends... OK lousy answer. There are 2 ways to fit louvres... as a louvre gallery inside an existing window and as a complete louvre window. Inside an existing window requires the window depth to be sufficient to take the gallery. A new window requires the old window to be taken out and the new fitted... if your old one is aluminium it's likely that you will need wide architraves to cover the gap. So best thing is to get someone like Robert Mason (Breezeway distributor Melbourne) to quote the replacement. But you need someone to install. Then there are flyscreens... Why not get an opening window from you existing window supplier, easier to changeover, and easy flyscreens. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 9178 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 4183 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 3270 |
