Browse Forums Windows & Doors Re: Dumb window question re sizes on plan 3Feb 09, 2010 12:21 am Candylea Doesn't that 2118 suggest it is 2118mm wide? Thanks Candylea but I know for sure that isnt it - I recall the sales consultant telling me the figure is the height & width of the window, I just cant recall which one is which On the plan they are ahown as 2118 & in the tender letter the same window is described as 21-18.......sure it must be height then width??????? Cheers Kim Re: Dumb window question re sizes on plan 4Feb 09, 2010 7:55 am OMG I guess I should be able to figure this out but if a window is shown on the plan as 2118 does that mean it is 2100 high & 1800 wide or 2100 wide & 1800 high, 2112 means it is 2100 high & 1200 wide yes? Cheers Kim Yes, you are right Kim. But the sizes are nominal, so a 2118 may be say 2057 x 1810. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Dumb window question re sizes on plan 5Feb 09, 2010 10:50 am ed @ EcoClassic Yes, you are right Kim. But the sizes are nominal, so a 2118 may be say 2057 x 1810. Ed Thanks Ed - am trying to buy blinds etc working off the plan. Guess that might not be as easy as I thought! I think most of our windows show as 2118 so I might as well ring the sales people at Coral & check with them for sure. Thanks again Cheers Kim Re: Dumb window question re sizes on plan 6Feb 09, 2010 11:19 am OMG ed @ EcoClassic Yes, you are right Kim. But the sizes are nominal, so a 2118 may be say 2057 x 1810. Ed Thanks Ed - am trying to buy blinds etc working off the plan. Guess that might not be as easy as I thought! I think most of our windows show as 2118 so I might as well ring the sales people at Coral & check with them for sure. Thanks again Cheers Kim Welcome Kim. Don't go by the plans to buy blinds... the inside and outside of most aluminium windows are different sizes. The nominal sizes given are for the outside, the inside is likely to be 40mm bigger (except ours ). Best wait and actually measure or ask the window supplier. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Dumb window question re sizes on plan 7Feb 09, 2010 12:51 pm Bugger - here I was thinking I would be all organised & ready when we moved in just to hang them! Oh well - thanks Ed - you have saved me from running around trying to return a dozen or so blinds in a few months! Cheers Kim OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19865 I have a box of quality drill bits that seem to be new but their engraved sizes covered by rust ,,,,I tried to sand them to see their sizes but still I am finding… 0 1387 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17167 |
