Browse Forums Windows & Doors Re: minimum toilet door opening size 2Aug 06, 2007 8:59 pm I would imagine 720 but I stand to be corrected... Re: minimum toilet door opening size 3Aug 07, 2007 8:25 am Actually, unless you have special mobility access requirements, I don’t think there is a particular dimension specified by the building code, it is more likely to prescribe ‘safe and reasonable access’ or similar.
We had a bifold door in our old bathroom, and the doorway was 680mm, so the clear opening was even less with the door folded open. But it was quite sufficient for an adult to get in and out. The door opening was enlarged to 720mm, and the door was hinged, when we renovated; 720 is a standard door size. Perhaps you could check with some door manufacturers to check out typical sizes used? My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6866 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5357 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15687 |
