Browse Forums Windows & Doors 1 Jan 26, 2010 3:07 pm I can't seem to find the information on the web. Is there a sheer blind that allows you to see out clearly, obscures vision in and lets the breeze flow through. Preferably without banging against the frame. Any help would be appreciated. Gravity. Its the law. At lock-up stage(lock-up stage) https://forum.homeone.com.au/viewtopic.php?f=31&t=25438 Re: sheer blinds that let the breeze through 2Jan 27, 2010 3:44 pm If there was a roller blind version of this I'd have them throughout my entire house! Re: sheer blinds that let the breeze through 4Jan 28, 2010 5:15 pm I visited a few stores and even they don't know of a blind that won't bang against the frame in the wind. Thanks for taking a look and having a think about it people. Cheers Gravity. Its the law. At lock-up stage(lock-up stage) https://forum.homeone.com.au/viewtopic.php?f=31&t=25438 Re: sheer blinds that let the breeze through 5Jan 28, 2010 5:36 pm You can get clips that you affix to the frame and when you pull the blind down you push the ends of the blinds into the holders. You can get them for outdoor blinds as well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: sheer blinds that let the breeze through 6Jan 28, 2010 6:01 pm Hey TM if I understand you correctly, there are blinds like you want although I'm not sure of the correct name but I saw them in Spotlight and presume others would stock them as well. I've also seen them in a couple of display houses and I suspect these would have been installed by specialist window stores. The fabric is open weave and while I haven't had them in my current house, I fitted Spotlight aluminium venetians and worried about them flapping in the sea breeze each afternoon but they are OK as long as I lock them into the bracket on the windowsill. Of course, if it's blowing a gale then anything will flap to some extent as the wind has to go around the blind rather than through it! Here's the url to show the brackets I'm talking about...they are called 'hold down brackets' but as I said there may be a special bracket for roller blinds. <http://www.fixmyblinds.com/brackets.html> Hope this helps? if I find anything else I'll let you know. Re: sheer blinds that let the breeze through 8Jan 29, 2010 6:09 pm They look perfect. If you put them to the sides of the frame(for a blind inside the frame) you'd barely notice they were there. Thanks, I was considering curtains but I'd prefer blinds. I'm building a relatively small house and I thought curtains would make it feel smaller. Much appreciated. Gravity. Its the law. At lock-up stage(lock-up stage) https://forum.homeone.com.au/viewtopic.php?f=31&t=25438 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7320 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 |
