Browse Forums Windows & Doors If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 Thanks for your thoughts. Do you feel your louvre sidelite security mesh is safe? I was thinking no window at all so no one can see if I'm near the front door, shadows… 2 818 |
