Browse Forums Windows & Doors If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13771 |
