Browse Forums Windows & Doors 1 Oct 10, 2009 7:08 am Hi All, I was looking over our final plans the other day (that we have now fully signed off on) and to my horror noticed an issue on the placement of windows to the first floor. As per council regulations, we had to get 2.7 meter ceilings to both ground and first floor. In doing so, the tender mentioned that "window head heights" are to increase but i didn't take too notice of the vertical placement of the window (thinking it would be similar to the display home). I got out the trusty ruler the other day and measured the following from the scaled elevation diagrams of our final plans : Master bedroom window : starts approx 1.8m from the finish floor level All the bedrooms : starts approx 1.5m from the finish floor level Our family aren't overally tall, but looking at measurements from the elevation diagrams seems like we will need a chair to look out through our windows and the kids will definitely need a chair to look through their windows. Have i measured correctly (ie from the finish floor level)? If so, what can i do now ? Re: Windows too high ?!? 2Oct 10, 2009 8:03 am What is between the top of the window and the eaves? If there is a fill of some sort, you should be able to readily move the windows down so that the sill is the same height as the display home. 1.5 m high sills is ridiculous and should be fixed (you might as well have skylights). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Windows too high ?!? 3Oct 10, 2009 8:08 am Hi Casa, We have 450mm eves and by looking at the plans, the windows sit flush with the eves. There is approx 300mm from the top of the window to the finish ceiling levels, which i believe will be filled with infill's (which i cant see as it will be masked by the eves & roof). Do i have enough time to change things now ? Will this affect bassix, council etc ? Re: Windows too high ?!? 4Oct 10, 2009 9:00 am I would get the windows moved down so that the window sills are at the same height as the display home. A minor change can be requested through Council and they would have no problem since it's better for all concerned. It would probably affect Basix, but I personally would proceed regardless and worry about it later (if anyone even notices). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Windows too high ?!? 5Oct 10, 2009 9:00 am I would get the windows moved down so that the window sills are at the same height as the display home. A minor change can be requested through Council and they would have no problem since it's better for all concerned. It would probably affect Basix, but I personally would proceed regardless and worry about it later (if anyone even notices). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Windows too high ?!? 6Oct 10, 2009 9:16 am aus_buster Master bedroom window : starts approx 1.8m from the finish floor level All the bedrooms : starts approx 1.5m from the finish floor level I don't think anyone would find those acceptable. I think someone was being quite stupid when they let that obvious mistake continue. Common sense should tell them it's wrong, wrong, wrong. Re: Windows too high ?!? 7Oct 10, 2009 11:04 am aus_buster Master bedroom window : starts approx 1.8m from the finish floor level All the bedrooms : starts approx 1.5m from the finish floor level Are you sure that that is right. I thought I would sketchup what it would look like on one of the elevations on our house it just looks very very wrong. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is this really what your plans show? View our blog at: http://room4acubby.blogspot.com/ It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8283 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39751 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5642 |
